Decoupled Data Architecture: External Variables, UI Grouping (Tabs-to-Groups), and Reusability
Currently, parametric modeling in Shapr3D is hindered by a “monolithic” architecture where variables are locked inside the design file. This creates three major issues for power users and makers:
  1. UI Clutter & Usability: In complex models (e.g., an electronics enclosure), I often have 50+ variables. This results in a long, flat list that pushes the History Tree off-screen. It is impossible to navigate quickly, and I am forced to use long snake_case names (e.g., lcd_screen_mount_hole_width) to keep track of things.
  2. Lack of Reusability: I use standard components across multiple projects (e.g., Raspberry Pi dimensions, standard screw sizes, manufacturer tolerances). Currently, I have to manually re-enter these variables for every new project. There is no way to import a “standard set” of parameters.
  3. Data vs. Design separation: I cannot treat data as a separate artifact. To create a variant of a design (e.g., “2024 Model” vs “2025 Model”), I have to duplicate the file and manually edit values, rather than just pointing the design to a different data set.
I expect a workflow that separates Data from Geometry:
  1. External Data Source / Import: I want to be able to import or link an external file (Excel, Numbers, CSV, JSON) into the Variables list.
    • Workflow: Create a spreadsheet with standard specs → Import to Shapr3D → Variables are populated instantly.
  2. Tabs as Groups (UI Organization): The import should respect the structure of the source file.
    • Outcome: If my Excel file has tabs named “LCD”, “Box”, and “PCB”, Shapr3D should create collapsible Groups or Folders in the variable list with those names.
    • This allows me to collapse the “PCB” group when I am working on the “Box”, saving massive amounts of screen real estate.
  3. Namespacing: I should be able to reference these groups in formulas using dot-notation, e.g., LCD.Width instead of lcd_width.
  4. Export: Ability to export the current variables to a CSV/Excel file to create a library for future projects.
This is a scalability blocker. I cannot efficiently use Shapr3D for complex, system-level designs where multiple components interact (e.g., PCB + Enclosure + Battery). Without this, I am forced to spend more time managing a chaotic UI list than actually designing. It prevents a professional workflow where “Configuration” (Data) drives the “Design” (Geometry), effectively limiting Shapr3D to single-part modeling rather than system configuration.
