Deleting from homepage
On the homepage it would be great if we get a visual of which model we are deleting, whether it be a colour around the box or the filename in the right click delete dialog.
I don’t get a mini heart attack thinking I might have deleted the wrong model. I’d like a visual clue/reminder which model I’m deleting.
I can’t visualise which model I’m deleting.
No, just reassurance needed.
Mine shows a blue outline around the project when I right-click on it in the app.
Odd, Mine doesn’t as you can see.
What version are you running?
I’ve worked it out - Doesn’t show the blue outline in RECENTS, but does show in PROJECTS. Thanks.
“Recents” definitely acts differently than “Projects”. For example, a single click on a project in “Recents” opens the project whereas in “Projects” it takes a double-click.
