Detaching a shape from an object
The title says it all.
Let’s say I projected a plane onto an object (think of a bottle and the projected plane would be the label).
I can then extrude the object (for example 0.5mm as paper depth) - so far, so good.
Now I would like to be able to have the bottle and label as separat objects for further texturing inside of Blender.
Is there a possibility to make the project plane (label of the bottle) a separat object inside of Shapr3D?
Hi, I will make 2 duplicate copies of the model such that I will then have 3 copies of the design.
Then use the Subtract tool to detach the individual parts of the model using the 2 duplicate copies while I still have an original copy of my design.
Here’s our short great video on the Subtract tool: https://www.youtube.com/watch?v=0JVbtFBuCPs&t=1s
Thank you for the advice! Seems a bit complicated to me, but i guess it gets the job done. :slight_smile:
