Divide lines equally
I’d love to be able to select a line (or multiple and select a divide icon to equally divide the line by a number I set. I can have one number Ron one line and separate number on another.
This will enable me, particularly when designing windows, doors, brickwork etc to divide the space equally for window panes, door panels, even angled brickwork.
This feature would enable me to quickly Crete equal units without having to calculate a distance and manually divide it and then create a line or rectangle and then pattern it, to then work out that I haven’t entered the correct amount of digits.
Calculating is hard and a click and divide (by any number) will speed up processes of making grids.
Until we get variables and math, this might save you a little bit of time and eliminate math errors. You just need to type in the total distance, and the number of desired sections ( plus 1 because each section requires a line on either side).
Thank you. I’ll use that for now :slight_smile:
