Hey guys!,
So quick little thing that bugs me as I do this 1000’s of times.
So I do tons of double-tap > sketch on face > push it extrude and the initial option is subtract.
At first glance not a big deal, but when i work on my bigger models it stalls for minutes. I have to : draw > select the sketch > pull it away from the model ( with the pivot readjusted on the face ) > extrude away > then move the new part back > then perform the operation on the parts I’d like. Having it default to slice any object in front of it is a big slowing down factor in my workflow. Is there a preference setting to disable this or to default to always “new body” I prefer the choice and also it saves on by mistake slicing through my entire model. image|666x500
On your picture, check that badge next to the dimension, you can select the type of boolean you want (to overwrite the default)
