I use shapr3d to design and export the files as dxf or dwg to import into carveco and create my toolpath for my CNC. Since the last update when I export my files and import them into carveco they do not keep their scaling. They import about 75% of the original. I don’t see any settings when exporting from shapr3d.
I am using shapr3d on my iPad.
It does not let me create the drawing like this because I only have a sketch in my file, not a body.
I’m using the export dwg from sketch function.
But all settings are set to mm as well when importing
What are your units? If you’re working in inches, try switching to mm. I think most CNC apps use millimeters.
All units are in mm and when importing it asks me wich units the file is
