I currently have a lot of files in vectors in Adobe Illustrator that i’ve been wanting to conver to 3D. I use mm as the measurement units in Adobe and everything is made to scale.
So my issue is that when i export the DXF file from Adobe and import it into Shapr3D the scale is always way off - an example of the most recent one is the Adobe file object is 30mm —-> and once imported to Shapr3D its ~600.xxxx mm (a large number that i dont remember exactly).
So is there a way to import dxf files to scale? Or perhaps is there a specific way to save files in Adobe to solve this pain point? I dont want to have to manually use the scale tool to downsize.
Any help is appreciated. thanks! ![]()
