Exported DXF file will not include text
I am trying to export a DXF file that will be easily used by a partner shop to plasma cut our steel sign. After spending forever trying to find out how to merge sketches which seems harder than it should be, I’ve now run into the issue of my sketch not including the text that I’ve added to the sketch when I export the sketch as a DXF. I’ve deleted everything I can from the project, and it is literally only this one sketch in the items tab, so I cant imagine why if the text is showing up in my drawing, that it won’t export with the rest of the drawing. Hopefully my drive attachments work, but that shows my project, the way i export, and then the dxf I get from it.
Here is what I found.
Your DXF file opened in an Vector Art program like Affinity Designer shows the lines are not joined/closed.
In Affinity Designer I merged it and joined it so now the DXF is one closed line.
Sign fixed.dxf.zip (63.8 KB)
