UPDATE: drawings are finally here: 4.0 - 2D drawings + new pricing
How do I get just a white model with lines like the one pictured in the guide for this?
If you project your model’s contours to a plane and export them as a dwg/dxf then open it in a CAD viewer an export it as a pdf/jpeg, it will look like the same.
A much more simpler way to export your model for visual purposes is to select Picture as an output. In the popup window you can select if edges and the background gris should be shown or not, etc.
That got me going in the right direction. To get the nice clean white look:
Bam done.
