Exporting should keep file type
Currently, when you export and pick the filename from the list, it does not adjust the filetype extension to match the file type. Example below - exporting as 3mf, instead of previously exported stl.
Selecting the previous filename, just copies the whole filename and hence the file type is incorrect.
The file type extension is changed to match the export type. So selecting ‘bracket.stl’ would export as ‘bracket.3mf’ (given that 3mf has been selected as the file type). Most application I use do this.
It’s annoying when one has to edit the filetype extension. Another example of a lack of appreciation for UI/UX from the devs.
Still not fixed! Perhaps it should be reported as a bug rather than a feature request?
Another 2 months and still not fixed :frowning:
