Exporting with texture?
Has anyone figured out a way to export files while maintaining textures? It seems as if anytime I import to another rendering program, I loose my materials and the body is unified.
I use Twinmotion a lot and export as obj. I can’t transfer materials over but the body definitely isn’t unified.
You can also select the option to export parts as individual objects.
This is exactly what I was looking for! Thank you so much! I was just downloading TwinMotion!
Just a word of advice. Sometimes I struggle selecting tiny parts in Twinmotion, particularly rounded ones. I recommend naming them before export so it’s easy to search for them in Twinmotion.
There’s lots of times where I’ve had Shapr open just to click in a part to see the name and then clicked Body_123 into TM (spaces are replaced by _).
