Extrude drafted
A problem with extrusion is drafted by default
It would help a lot if shapr3d team disconnect each action from another
Because I suspect this happened due using scale tool.
Hi @MrJack88, that looks weird! Can it happen, that the sketch plane is not perfectly perpendicular to the desired direction of your extrusion? By default, all extrusions are done perpendicular to the drawing plane of the base curve that was extruded - without any draft for sure. What is the result if you do the extrude as a New Body?
Can you please send me the workspace to let me take a look at it?
Ops :upside_down_face:
My bad :sweat_smile:
Thanks :smiley:
no worries :smiley:
