Paramétric Hélix slot probleme…(and solution)!
Hello, I have a problem making a part with very precise tolerances.
I can’t build the gray part guide to create a 36° rotation movement for a translation of the red axis of 24 mm high.
The yellow axis must remain in contact with the two surfaces.
Can someone explain a method to me? Thanks
If I understand you right you want to make something like that?
Here is an interesting thread
Yes, absolutely
I tried several techniques, but never succeed, could you explain your method thank you very much…
I did two holes in edge points
Then drew a sketch in the start position and revolved 36 degree 24 mm
Then substracted revolved body from tube
I decided to 3d print this model, that’s why I added 0.1 mm tolerance
Amazing… How simple you made that…
I was just reading the topic From 2024… and the complex solution they came up.
Thank you very much for your help.
They did precise math calculations. I just eyeball it :slight_smile:
Main problem is to find precise angle of that sketch
With the angle of 111.35 degree I got most accuracy of 5.9918 mm instead of 6 mm
I was asking myself the same question… I made some visual corrections to find the best angle, but the solution works well, more than enough to create a prototype with my 3d printer…:slight_smile:
Here’s a somewhat precise method. My slot is 4mm wide and the rod that slides up the slot is 3.6mm dia. The rectangle used in the revolve is rotated 54° which will be normal to the 36° angular slot that is 24mm high. After the revolve I added 2mm length to each end t compensate for the diameter of the 3.6mm rod. Hope this helps.
How did you come to 54 degree? Have you used any formula?
Not sure if this is totally precise or not.
90° minus 36° angular rotation = 54° starting angle of the slot that moves upward. Does that explain it?
Quite interesting. I used the same method, which I explain above, but to get precise result had to rotate rectangle on ~68 degrees. Only difference I have 6mm width slot and 6 mm rod.
I too tend to eyeball designs (meaning examples). I used an intuitive approach on this one getting the 54°.
Each rod is copy elevated 6mm and rotated 9°.
Note, my first post said ‘somewhat precise’. :wink:
Yeah, I missed that :smiley:
Hi
I made a precise parametric design some time ago to do this kind of slot so I share it here.
It is accurate even for large values of the helix angle and thick tube; it also handles clearance.
You just have to set 7 variables:
  • d_out, d_in, l : dimensions of the tube
  • d-pin : diameter of the pin
  • e, alpha, clearance : dimensions of the slot
Parametric Slot milling 0.7.shapr (626.1 KB)
