On the MacBook version of Shapr3D, there is no two-finger rotation function, which makes it difficult to freely rotate the view and see the model from different angles. This is a significant inconvenience compared to the iPad version, where two-finger rotation is a very intuitive and useful feature. I will upload a video showing how two-finger rotation works on the iPad.
I would like to be able to rotate the view with two fingers on the trackpad of my MacBook, just like on the iPad. Alternatively, it would be great if there was a shortcut key that would allow for two-finger rotation. For example, pressing and holding a specific key (e.g., Option or Command) while using two fingers to rotate on the trackpad, or using an Option + arrow key combination, would be a good solution.
Without this feature, it is difficult to quickly and accurately check the model from various angles. This makes the overall workflow inefficient and slows down the design process.
Yes, this is a significant workflow blocker. It is not so severe that I cannot use Shapr3D for work, but it definitely slows me down and makes the user experience less enjoyable. Especially when I have to visually present various components of a model to others, the lack of intuitive view rotation makes the process take a significant amount of time.
