Generative Design Tool
Creating organic and optimal parts to save on weight.
This feature would allow for a structurally optimized body to be generated based on the location of mating faces and joints.
I am unable to create parts that are perfectly generated for both weight and strength in mind for use worth additive manufacturing.
It is another reason for me to utilize a tool such as Inventor because it incorporates this into its software
Hi gamoruso, generative design is not in our focus in the near or mid term. How are you using generative design right now and what are you designing with it?
I would also be really interested in using this. It’s disappointing to hear that it’s not on your roadmap-
