Outstanding work!
Wow! You did all that in Shapr3D? Excellent!
Mike…
Thanks McD ![]()
Yes, all is made here in shapr3d
Great job! I’m curious about how you accomplished shaping the roller coaster section. How did you manage to create a sweep along a spine in a space other than the x, y, or z plane? I found this task challenging in 3Dshaper compared to other software such as Rhino, Revit, and even AutoCAD. Here you can place points on x,y,z space or you can create a spline curve in any direction.
I was thinking the same thing, how did you do the sweeping
Well what I did in this case was use the add button and select construction plane ; then type construction plane and select perpendicular to a curve or point.
From there you can move to any point within the coordinates.
Here I also leave a photo of a line and a perpendicular plane
The planes can also be tilted or rotated and that will allow you to create a path of lines and at the end use the sweep options to create the pipes.
I already answered the question, I failed to mention that it was quite difficult to take care of the curves but it turned out pretty well I think ![]()
