Hi everyone, I’m facing two issues with Shapr3D. First, I want to place objects on a flat surface and later color each one separately in other software. For example, a flat circle with an arrow on it, where I want to 3D print each in a different color. Right now, I’m slightly thickening the arrow to color it. Any better solution?
Second issue, when I import two connected squares into Bambu Lab, I can only color them as one. If I import them separately, I can color each, but they disconnect. Is there a way to keep them connected and still color them differently?
In the image I’ve shared, I’m showing an object in Bambu Lab that is completely flat but has different parts colored separately. I want to know how I can assign multiple colors, like two, three, or more, to an object in Shapr3D using sketches I draw on it. And when I export it in formats like 3MF or others, I want to ensure the colors stay intact when I import it into other software.
