Hi, I need help making a thread over a conical object
hi, so this is as far as I got as I am trying to get the thread accordingly onto the surface of this conical pillar.
is there any way I can manipulate the distance between each rotation so that I can fit it onto the object’s surface with 0 distance and 0 overlap?
thanks-
Hello, I had the same problem or question a while ago, but it seems to me that the best way to do this without so much complication or incorrect results is: Using construction plans, you can add construction plans that coincide with the thread, decreasing or increasing the radio. If it is not understood as soon as I can I will upload some photos and maybe someone else will have a better idea. :grinning:
Also there are some videos on YouTube that you can take as a guide.
Like this one :point_down:
