Hide/Un-hide en masse
I have a large number of bodies I have collected into a folder and I wanted to save them all in one fell swoop using the “Save first level items”. This meant I had to unhide all of them (Because I have other hidden bodies so I couldn’t use “use hidden” toggle) and it got time consuming. How hard would it be to add the ability to right click highlighted layers, or even a folder with layers in them and find a “hide/unhide items” option?
I requested this awhile back also. I spend so much time hiding and unhiding items. With a group of items selected you should be able to hide/unhide them by clicking on one of the icons.
Also, if you have a folder of items there should be a way to see if items inside that folder are hidden without having to open every folder and check inside.
