Hello,
I’m having an issue removing the fillets from my model. Shapr3D won’t let me remove them.
I created a model (see attachment) with 1 mm fillets on all edges. Now I need to add an additional wall (marked blue). To do that, I first tried to remove the fillets, but without success.
Do you know of any solution to this problem?
Thank you in advance!
Kamil
In the history. OR sometimes you must select the entire fillet on and around all continuous edges, then make your mod and reapply fillets. Sometimes Shapr won’t let you select sections of filleted edges.
For some reason I had to select all edges of the fillet I wanted to get rid of. Could not delete it unless I did.
Sometimes Shapr misbehaves like this. Order of selection can be important is some operations
Thank you, Oregonerd, for your quick reply.
I already tried selecting all the edges manually, but unfortunately that didn’t help.
EDIT: The tip about using the History feature solved the problem. Thank you!
