How can I subtract a sketch around a body
I have this tapered box I would like to remove a sketch from all around it.
You will notice in the screenshot below, there is a sketch on the left side. the idea is to remove that piece out of my body all around.
I couldn’t figure this one out, what is the best tool to use to achieve this? Am I approaching this wrong? I’m modelling based on what you think in the background (Mesh body). I’m trying to replicate that.
Tap the sketch and then drag from the back of the sketch across one side of the square object to cut the shape. Then rotate the object 90 degrees and repeat the cut. Repeat for the other two sides and you are done.
yea I tried that previously with varying success. The box has a draft angle, so that sketch initially cuts into the body then protrudes out at some out. At some point, I managed to align the angle of the sketch but again had varying degrees of success. Especially at the point where I had to rotate 90 degrees and then rotate again.It wasn’t aligning correctly.
I had a quick go at it. When rotating the object, make sure your rotation point is in the middle.
That box doesn’t have a draft angle or?
But that gives an idea actually, thanks mate
Make a construction plane trough the upper edge of your box ,
Project your sketh to the plane , after subtract as Stephen said…
I ended up changing my approach. Rather than adding the draft angel to box, I added it to the sketch of the cutout I want to achieve.
Hi Acegreen,
Welcome to the forum.
You should also consider the sweep tool for this kind of work, as you can sweep a sketch along one or several body’s edges.
Thanks this is exactly what I was looking for. I tried profile but clearly misunderstood its functionality.
I was actually hoping to start off with a cross section exactly as you did.
Appreciate it mate
On a separate note, do you happen to know why when I try to union two bodies, it doesn’t work with no an error given?
The second body just get renamed to the first but they both appear in my folder?
Maybe you have selected Keep Originals : On when using the union tool?
If so, the union tool creates a third body and preserves the original ones unchanged, so you ended with 3 bodies.
If you switch it off, you will get only one body as the result of the union.
No, its off, I union’d bodies before and it worked, but this time its just glitching for some reason. I can even rename the second body and when I union again, it will change the name but not combine the parts, nor create two new parts (keeps originals is off as mentioned)
edit: I also tried toggling keep originals on/off, just to see if that would fix the glitch, but no it doesn’t.
If you upload the file, we could check it and look for the problem.
@PEC Great solution there with the Sweep tool :+1:
Will a public link work?
That link is only the Webviewer. We would need the actual project file exported as a Shapr project.
Oh I’m on the free version, not sure if that’s possible
