How can merge Two or More Sketches
How can I merge two or more Sketches to One Sketch-Level ?
Projection dosn’t work …
Hi
Have you try to use a Construction Plane and Project on it ?
Construction Plane not needed.
If I project two sketches, I get many copies of lines.
I created a screenvideo… but new users cant upload files :face_with_symbols_on_mouth::man_facepalming:t3:
realy top top :flexed_biceps:t3:
Can you send your project to shaprd3d@tsbl.net?
It is definitive a bug !
no matter what and how I try, the sketches are copied multiple times from one layer on top of each other.
Thats a serious issue …
Could you please submit a ticket on the support portal?
Please include: App version, device specs, screen recording and the .shapr file you are experiencing the issue with
here a simple video where I brings together two sketches 'sketch1 et 2) in one. After you can delete the plane if you want.
Click one line of each Sketch please…
Is there only one line or many lines ?
Many thx for your support :folded_hands:
