How do I create this hexagonal parting line in Shapr3D?
Hi there,
I’m trying to create this hexagonal parting line that looks like the image shown in the attached. Does anyone have a solution for this?
Thank you so much!! This is super helpful.
Wait TigerMike… How did you make the angles after the extruded cut?
Use the Move-Rotate tool on the side walls.
A raised wall also works making the hex parting line. After making four rotated copies, do a Union. In my initial example, I used Intersect.
Wow I didn’t know you could move/rotate angles like that! I figured out how to do it with a chamfer but the angles aren’t as custom to the degree. Thank you so much!
