How do I figure out where the break is?
I had selected the edges from an object and projected them onto a plane. But I cannot for the life of me get the edges to be contiguous to create a sketch that I can extrude. I have zoomed all the way to .0001mm at every endpoint to make sure they were connected I found 2 spots, and connected them. But something is still preventing it from becoming a face.
Is there an easier way to do this? What am I missing?
Also not sure if it’s related. When I select one edge on one side of the endpoint it highlights the endpoint. But the edge on the otherside does not?
Thanks!
Usually, I can easily find the gap just by eye. If you can share the project, I can help you find the problematic areas.
Another way to find the gap is to add helper lines that divide the sketch into several profiles — this helps identify exactly where the problem is.
S700_mount.shapr (18.8 MB)
I’ve attached the file here. Thank you.
This is how I usually correct this kind of sketches
S700_mount.dxf.zip (12.5 KB)
I’ll usually draw a rectangle overlapping the shape and then try to select the profile formed by the intersection. If it selects, then the break is not within the rectangle and I move the rectangle to try again. When the profile stops becoming selectable, you’ve narrowed down where the break is.
