Hey all,
I’m brand new to CAD modeling and design. Trying to self teach and learn through tutorials. In this sketch I created in the image below, how do I go about giving this sketch a body to then extrude it?
Thanks!
Your sketch has an opening somewhere. If it were closed it would have a slight blue cast. Draw a circle next to it and you will see what I mean. Only closed flat faces can be extruded.
Oops. Disregard… You used a construction line. Those are for reference only. Try selecting it and see if you can change it back to a line in the constraints menu on the side.
Still sipping first cup of coffee, Sorry.
You need to be out of sketch mode to extrude.
Yep! This was the issue. The ladder of your comment. Thank you so much sir!
