How do you model threads? Add matl or subtract matl?
Just curious, how to you guys model external threads, like on a bolt. Do you create a triangle to add material to a shaft that is at the root diameter? Or do you create a triangle to subtract material from a shaft that is at the major diameter?
For example here is a screenshot of where the matl (fundamental triangle) is added to the root diameter shaft…
Most of us do not model the threads. I import bolts, nuts, pipe, etc., from McMaster-Carr using STEP file format. Then add or subtract as necessary.
I often make nuts and bolts in Shapr just for the fun. There are a couple of videos on YouTube showing how to make them.
https://youtu.be/G6Roo0ztiuM
https://youtu.be/TS0OmrwH1XI
Hi
I always subtract. It is the way bolts and screws are actually manufactured and it is, in my opinion, the best way to get a clean start for the filet when you model chamfer before doing the subtraction.
Best regards
PEC
This is s great video! This answered what I have been looking for.
Just for giggles I added a thread to a shaft. Oh yeah, now I have to clean up the thread where it goes past the end of the bolt. Oh and then I’ll have to add a chamfer. Aw, no fun. I think I’ll go back to subtracting my triangles from the bolt! :sweat_smile:
That’s a good effort.
haha, I thought I was the only one! Mcmaster’s catalog is My Go-to for threads. Embed the bolt, subtract, voila! Threads!
Same, so easy to do !
