What would be the best way to continue this 2mm x 2mm cutout pattern around the curved edge?
This is how I would do it. You have to do a little math beforehand to determine the spacing around the 90° bend and onto the flat areas. I can explain my numbers if you like.
Brilliant, thanks @TigerMike - i tried the circular pattern tool, but i was missing the key ingredient of setting the rotation axis.
