I am trying to continue this pattern around this curves faced. Does anyone have any insight on how to do it??
Did you use the linear Pattern function to create what you have? If it’s a circular arc, you could use the circular Pattern option around the arc.
I don’t have an answer but will instead add another question that the OP’s question made me think of… Could this be achieve using “follow” in some way? If not, Maybe a “Follow Pattern” function could be a nice addition to the pattern tool set.
