How to make a perforated cylinder (pipe)?
I would like to make a cylinder (a pipe) which has honeycomb (preferably) perforations. What is the way to achieve that? What would be the way to make any surface perforated?
Rather than perforating a pipe, I created a pair of hexagonal nuts (offset diagonally) then performed a circular array before creating a linear array to form the length of the tube…
In this second example, I first created a ‘tree’ of shapes (hearts in this case) then used the tree to subtract from the cylinder.
By scaling the shapes from the centre (loft) you can subtract from any diameter pipe and the hole shapes will remain scaled accordingly…
EDIT: The scaling is not totally reliable. While the hearts scale just fine the spaces between them changes. Probably better to model a single pipe then scale the pipe to the desired size.
Now it’s just getting silly…
In this example I simply created a few holes then copied them around the pipe and then along the length. There are so many ways to achieve similar results…
Wow, that’s awesome - can you make a short tutorial on how to achieve this?
