Honeycomb tube
Hi, my name is Olivier and I’m trying to make a honeycomb tube but I have no idea how to start…
Does anybody have an idea ?
Welcome!
Use the polygon sketch feature and select the hexagon. You should be able to go on from there :slight_smile:
as suggested by @SM1 :grinning:
If you were thinking at something like the next picture, it is much more complicated.
For this I extruded a hexagon, rotated if (new body selected) 15 deg. Selected all. Moved them up (new body selected). Selected. All and repeat. I moved all resulting bodies into anew folder (easier to select later). Them extruded a tube (new body). Select the tube then choose subtract…… select the folder with the hexagons. Done.strong text
Thank you all, that’s exactly what I need for the first step of my project.
I hope to be able to do the next steps !!
