How to make Loft tangent to adj faces in Beta?
First, it is quite surprising to me that i can select a curved solid face as a section of Loft! As i remember, Solidworks allows us to pick a planar sketch/ planar face only for a Loft.
Second, parametric modeling works quite well in Beta. When i can move the cutting sketch, the following commands/features can be updated automatically.
But how can i make the loft tangent to adjacent faces? Now, i dont know how but make a fillet.
Project a sketch or face onto the cylinder then use Loft.
Here’s a little something else.
Thanks for your input, TigerMike. Besides from this question, i cannot edit Loft “after build”. I cannot find which sketches were chosen to build it, or cannot replace them by other curves, or add additional guide curves.
@dicksonsham in the current build you can drive the lofted body by changing the sketches you used for the build. Reordering the profiles and adding new profiles and/or guide curves is on our backlog, not yet available in the beta.
Thank you very much! In latest version, loft function becomes complete! G1 & G2 controls are added! Profile/Guide can be re-define after build!
Profile can be a sketch /curved face. G1/G2 added with magnitude value. Very impressive!
