Hi Shapr Team. Thanks for the last updates in the past. Make fun again to use the beta. With the last update you released my awaiting loft update to generate a tangent beginning and ending. I usually uses a similar sketching plane to force the loft in my design to be tangent. My goal was to avoid this step to get a better workflow because the loft doesnt work sometimes with my method. In this test i used only three faces to let it simple. I tried every configuration and in one case it worked on only one face with G1. G2 doesnt work at all. Even if i only used G2 fillets on my hole design. I also dont know how the tangent magnitude work or what this mean. Could you please explain that? If i changed the number the loft failed. Is this normal or is this adaption not working at the moment? In the end the tool dont work in the way i need or i expected. Is my design or method fault? And a other thing i need help, if i mirror sketches to recreate the loft to recieve control to asymetric adaption dont work. I checked all sketches and the have the same intersection with the body. Why it failed?
Best regards
