I want to use replace face on the face the red arrow is pointing to, in the image below, and align it with the face the blue arrow is pointing to. I cannot figure out a way to select it. I have tried the following…
- Selecting Replace Face, then using the Items panel to turn off the object blocking the face. This will not work as the Items panel is greyed out.
- Selecting Replace Face, then dragging a selection box to select face. This does not work because Shapr3D is only selecting faces that are visible.
- Make the object blocking the face transparent so I can select the face behind it (sort of like Sketchup’s X-ray view). This does not work either because Shapr3D only recognizes the faces that are visible.
- Dragging a selection box to select the hidden face and then initiating Replace Face. This does not work either as Shapr3D only recognizes faces that are visible.
I am stumped at this point and looking for suggestions. There other ways that this can be accomplished, but this seems like an operation that should be possible. What am I missing?
