Select face through show hidden edges
Is there a way that one can select the face of a model when the face is in a difficuilt to reach place such as the photo below
The only way that I can select the face is by zooming in all the wau through the model and then you lose perspective of where exactly the offeset face or extrude is
I just ran into the same issue last night, when you do a window select toggle thru the “Tab” key to pick faces only and then you should be able to select that face even if it is inside the part.
Hope it works for you, I think Shapr3D will need to eventually add a way to toggle select thru the model to do this easier.
