How to turn a spiral coil (helix) into a hollow tube
I have a spiral wrapped around a central stem. I need to hollow out the spiral into a tube with a 1.5mm wall thicjness.
When I select the spiral, and choose “Shell” it SEEMS to do so, except that the far enf of the tube is blocked off.
Any idea what I might be doing wrong?
If you select both sides when you shell, you will create a hole.
If you only selected one side you can add more sides in the history panel.
Top and bottom
So simple. Thank you.
