How to wrap this around the entire surface
Hi! Could anyone please tell me how I would copy this design to go around the entire plant pot I am designing? I’ve tried projecting it around but it ends up warping the design. Any and all help is appreciated! Thank you!
Here’s a Q&D representation. Copy-Rotate the cylinder and use the Intersect tool.
You’re a genius Mike. Your posts are always worth reading. I’ve previously struggled with making tyre treads with Projection and seeing them warp more and more as I worked around the tyre circumference.
Intersection was the answer all along. Thanks :+1::clap:
