Offset: I can’t offset the height of an object to level out with the height of the object it’s adjacent to. Think of a circle within a circle… I’ll offset surface of large circle but then I cannot offset surface of smaller circle to be even/level with the larger circles surface. It’s like it refuses to do it.
Rotate: if lets say I draw a hexagon shape and offset top surface to create a 3D object, I can’t rotate it to get it lined up with the X or Y axis. I’ve tried everything
Grid/Plane Level: when resizing (or moving) around an object, I cannot get it level back on the grid/plane (the Gray grid mesh- whatever it’s called). I’ll move it up and down and pray that it’s level on there. This is very annoying. Although I’m very new so maybe it doesn’t need to be flat on the grid? Can it be floating? Does it matter? If it does please help.
As a new user I cannot upload video of my issue sorry. I hope I explained it thoroughly…
Thank you!
