I cannot add a dimension between a line and a circle in sketch mode
After several hours of reading documentation and trying various tutorials, I am extremely frustrated that I cannot add a dimension between the edge of a square and a circle on the square while in sketch mode as show by several tutorials. I can do this on my I pad, but cannot get this to work on my windows 11 computer. ALL OF THE VIDEOS show the instructor just dragging the mouse cursor from the edge of the square to the edge of the circle and the dimension appears, but when I do this it does not appear. I go into area selection mode instead. None of the documentation actually explains the mechanics of creating dimensions this when using a PC. Can anyone explain to me how to do this? The example that I am using is a square that is extruded and then I click on a face to create a sketch. On the sketch within the square, I create a circle. I want the circle to be a specific distance from the edge, but I cannot do this. Note that I have not issues when using my IPad, but the same process on the i pad doesn’t work on the PC version of Shapr3d.
Did you try making a construction line and setting it’s length? Screenshot of the problem could help.
The tutorial that comes with the Shapr3d program doesn’t do that. Its the tutorial “Create a sketch on your 3d model” video. I cannot create the dimension line as the instructor does in the video. Every YouTube video that I watched doesn’t explain this either.
Thanks for the help.
Can’t seem to find that particular tutorial. Can you link it?
Also check you appearance settings next to the nav gizmo.
Hi @rtschramm
Perhaps the confusion comes from the fact that on iPad, you can select multiple elements simply by tapping each one. On Windows and Mac, you need to press and hold the Shift (⇧) key while clicking on the elements you want to select; in this case, the center of the circle and the edge of the box.
