I want to create a shape that goes from a rounded square base to a circle following a curve. But Shapr3D won’t do that, and don’t know how to achieve it.
Divide the flat sketches along the guidelines. So your sketch will look like X in the middle for both top and bottom.
Thank you for your help, Jean-Phillipe.
I also think there is a loft bug, I was originally going post this before, but couldn’t repeat the loft.
FWIW, here’s a variation with twice the number of guide lines.
Your kinda helping Shapr to make it work, but in other software that shouldn’t be necessary, maybe just Shaprs limitations or a loft bug?
Actually in my case it was an user error.
The order was wrong.
Correct
Select sketch than second sketch hit loft and add guides.
VS
Wrong
Select both top and bottom sketch, loft and add loft than guides (how it works in different software). ![]()
Correct
I selected the bottom sketch, then the guide lines followed by the top sketch. Worked fine.
