I would like to be able to create threads easily
Id be able to make threads easily. This will allow me to easily create nuts, bolts, jars, lids, etc, easily
Be able to create threads by using simple measurements. Add how many times that the thread can revolve around it, and make it easy to make a nut and a bolt
It is harder to do with the revolve feature, and I have to go to fusion 360 to do it.
Is this a workflow blocker for you? Is this why you can’t use Shapr3D for work? Is this slowing you down? yes
Hi @electronic_crafter , why do you need modeled threads? Do you want to 3D print them?
Hi Istvan,
I second this feature request. For me, modelling threads is important for visualizing and checking tolerances - and yes a lot of my stuff is 3d printed first. I understand it’s computationally expensive though and a demand on processing. Threads and sheet metal are the only reasons I now go to Fusion 360.
Thread annotations are coming soon, modeled threads are also planned, but we don’t know exactly when we’ll implement it.
Any update on threads ? And yeah, I would like to print them. I already do, but I need them in Shapr3d also.
Yes, I really need them too. Always if I need to print some metric thread, I have to jump into F360 and create there.
Also I would like to ask you what about visual feedback of fully constrain sketch? Any new info?
Any updates on this?
We released the first version of threads, more functionality to come.
Read the announcement: 26.210 – Introducing the Thread tool, new sketch tools, expanded import support, and workflow improvements
Help Center article: https://support.shapr3d.com/hc/en-us/articles/31509261684508-Tool-menu-Thread-tool
