Cad file formats are completely new to me but I am trying to learn the IGES file format. I exported a simple cylinder from Shapr3D as IGES.
cyl.shapr (4.3 KB)
As I read through the spec and compare that to the IGES file produced by Shapr3d something does not look correct. Either Shapr3D has a bug or I misunderstand how Hollerith format works (which is very possible, I am no FORTRAN expert):
This is the Global Section from the IGES file:
1H,,1H;,89H/var/folders/cg/xpwdhpv9635ctpsvh4w5rl900000gn/T/4204B791-548G 1
9-43AB-8ACF-5920E0F3EA0E.tmp,67H/var/folders/cg/xpwdhpv9635ctpsvh4w5rl90G 2
0000gn/T/export/temp_export,7HShapr3D,3H3.0,32,24,8,56,15,89H/var/folderG 3
s/cg/xpwdhpv9635ctpsvh4w5rl900000gn/T/4204B791-5489-43AB-8ACF-5920E0F3EAG 4
0E.tmp,1.,2,2HMM,1000,1.,13H210309.191307,1D-05,1000000.,,,9,0,13H210309G 5
.191307; G 6
As a concrete example of the issue, shouldn’t:
89H/var/folders/cg/xpwdhpv9635ctpsvh4w5rl900000gn/T/4204B791-548G 1 9-43AB-8ACF-5920E0F3EA0E.tmp
be encoded like this instead?
98H/var/folders/cg/xpwdhpv9635ctpsvh4w5rl900000gn/T/4204B791-548G 1 9-43AB-8ACF-5920E0F3EA0E.tmp
I believe all the length values are reversed (or something). I expect a “strict” IGES parser will blow up on that and has a big potential for data frame alignment issues if the values are actually parsed.
This is another export from iPad version:
1H,,1H;,129H/private/var/mobile/Containers/Data/Application/74E1F485-0FAG 1
9-4366-BC85-7F9A102E31C7/tmp/45F0381F-3B85-4A03-9D9E-BB53A645FBEB.tmp, G 2
107H/private/var/mobile/Containers/Data/Application/74E1F485-0FA9-4366-BG 3
C85-7F9A102E31C7/tmp/export/temp_export,7HShapr3D,3H3.0,32,24,8,56,15, G 4
129H/private/var/mobile/Containers/Data/Application/74E1F485-0FA9-4366-BG 5
C85-7F9A102E31C7/tmp/45F0381F-3B85-4A03-9D9E-BB53A645FBEB.tmp,1.,2,2HMM,G 6
1000,1.,13H210309.213201,1D-05,1000000.,,,9,0,13H210309.213201; G 7
129H/private/var/mobile/Containers/Data/Application/74E1F485-0FAG 1 9-4366-BC85-7F9A102E31C7/tmp/45F0381F-3B85-4A03-9D9E-BB53A645FBEB.tmp
should be
138H/private/var/mobile/Containers/Data/Application/74E1F485-0FAG 1 9-4366-BC85-7F9A102E31C7/tmp/45F0381F-3B85-4A03-9D9E-BB53A645FBEB.tmp
