Import Solidworks files with Sketches
I am trying to work with Solidworks files but I could not manage to import the sketches. I can only import the Bodies. Is there a possibility to solve this issue?
Hi Jessi, at the moment importing sketches from SOLIDWORKS files is not supported. Can you help us understand your use case for importing the sketches from SOLIDWORKS?
Hi Istvan, we need that in order to work together with other people using other software at our university. Some use Solidworks, others use Autodesk Inventor. I would prefer using Shapr3D but unfortunately I can not use it if the sketchplanes from the others can not be importet.
