Solid Edge Support
Hi there,
I started using Shapr3D a couple of weeks ago, coming from Sketchup I’m blown away how easy to use and capable this program is. Also amazed how frequent you update new features to the app, amazing work from the developers.
I just saw that it is possible to import Solid Work files now - Part and Assembly. Is there a chance to implement Solid Edge as well? It is also Parasolid based, so I guess it should be possible, right?
My CAD department works with Solid Edge and I would benefit a lot if I could use some of there existing drawings and parts.
Keep up the good work
Matthias
