IMPORT SVG and PDF into SHAPR3D sketch format
IMPORT SVG and PDF into SHAPR3D sketch format, not only as images, but as interactive vectors/splines inside SHAPR3D
Now, we can only import DWG or DXF as sketches. SVG as images, not as vectors. The problem is the good vector interfaces are the old ones_illustrator, as a simple example. Illustrator have a very simple yet powerful and time tested interface to draw precise vector interfaces. Instead of constructing a interface copy with all that features, simply allow us to import SVG/PDF files directly as sketches. Illustrator on MAC does export DXF/DWG, but iPAD illustrator does not. If I want to import a vector, I have to put down iPAD, open a MAC, export from illustrator, wait for the cloud to update, an then import my DXF sketch.
Not leaving the IPAD when doing complex vectors in Illustrator and exporting as PDF/SVG before importing into SHAPR3D. Even other good vector apps for IPAD such as GRAPHIC and/or AFFINITY DESIGNER IPAD VERSION does not export DWG/DXF. So, you have to create your vectors in a CAD app or inside SHAPR3D, and the interface for vectors on CAD apps are precise but limited.
If SHAPR3D is designed to give freedom to designers to operate in a IPAD, if you have to leave the ipad all the time and open an asset in a MAC, that freedom is lost.
Faster work. Better access to other vector interfaces.
Is something that make my workflow slower. Ok, is possible to live with just DXF and DWG. But, If I have to change hardware to export an DXF, or change the interface that I like and start using another one, worse, but that does export DXF, both cases are not good outcomes. It will be simple and easy to just allow us to import SVG and PDF as vectors.
