Is it possable in the 14 day’s trial version to import an stp file?
Hi! During the free trial, you’ll have access to all Pro features so you can explore everything Shapr3D has to offer before deciding on a plan. You can find more details about Pro features in this article.
On the desktop computer it worked, but not om my Ipad. The files I’d like to import are located in a cloud surrounding. I can go to the right folder and the files (stp) are vaguely visible, but not clear like other file types such as pdf and dxf. Those files I can import. The stp I can’t. Is there a solution for this?
I try again , but not work in safari
Have you tried to replace the file suffix from .STP to .STEP and see if it imports?
Yes I did, that didn’t solve the problem. On a windows desktop there was no problem to import them.
Are those files stored on some cloud services?
The files app on the iPad may not allow the download of certain file types in the import flow. In these cases, you have to manually save the files on the device (e.g. downloads folder) and load them into Shapr3D from the offline location. Can you please give this solution a try?
