Improved Pan in Vision Pro
Requested Feature
Please provide a better means of doing a pan. I suggest that most people would be using at least a mouse pad or mouse and probably also a keyboard, when using Shapr3D on the Vision Pro, and that the improved pan should be based on these. For example pressing on the keyboard at the same time as driving the pan with two fingers on the trackpad or some equivalent on a mouse.
*The very worst feature of using Shapr3D with Vision Pro is the lack of a convenient and reliable pan control. This lack means that attempts to pan result in wasted time because the objects can unpredictably zoom instead of panning - or as well as panning - and also tilt at the same time.
A reliable pan control would make Shapr3D much more usable on the Vision Pro, and the lack makes the use of the Vision Pro clunky and frustrating.
Without a reliable pan control, use of Shapr3D on the Vision Pro is frustrating, slow, and mostly unusable for anything other than demonstrating existing designs, rather than actually creating or editing them.
