Intersection curves
I need to create edges that curve in multiple dimensions. In other CAD software, I’ve done this with the “intersection curve” feature, where you sketch the curve from one perspective, turn, sketch it from another perspective, and then use intersection curve to generate a single compound curve that looks like both sketches from the two projections used.
I want to be able to define complex compound curvature on the edges of parts.
As stated above - complex features that curve in multiple dimensions.
