iPad Pen Sensitivity is driving me crazy
In Modeling mode, the app is WAY too sensitive, instantly selecting everything when I’m just trying to grab a plane.
In Visualization mode, it’s fine — select a plane, and it stays put. I can soft double-tap to select all with no problem.
This bug has been around for a while.
Anyone else struggling with this?
You are not alone on this issue :grimacing: So there is a solution that I have found works for me. It is not Shapr3D but rather the pencil. go into your pencil setting and deselect pretty much everything. You should see a considerable improvement :grinning: This was previously covered under Apple Pencil posts.
Hope this helps,
Dave
Hi Dave,
Thanks so much for your help.
In my Apple pen settings I had most of them turned off, except for “Only draw with Apple Pencil”, so I turned that off as well and, though the issue it’s not completely fixed, I started seeing improvements.
Thanks again!
Bruno
