Please give us more settings
I use Shapr3D primarily on an iPad Pro w/ Apple Pencil Pro but often switch to Mac when I need to export since my main use case is designing for 3D printing (FDM).
In both cases, there a lack of customizability.
Here are some settings/behaviors that frustrate me that I wish I could change:
  • Apple Pencil tap does nothing - it would be great if this could be customized to perform a specific action.
  • Apple Pencil squeeze does nothing - same as above
  • Applying constraints to a group of entities resets the selection. This is particularly frustrating when I know I have several constraints to add and I have to manually re-select all the targets. It would be great if there was a way to toggle this behavior - especially if it showed up in the list of customizable actions for Apple Pencil actions.
  • Add the ability to adjust the tolerance for how close/far the pencil needs to be on a line. OR give us the adjust the line width of edges and size of verticies which should help with selection AND give us the ability to visually pick out these entities based on our preferences.
