Is there a ruler?
Please forgive me if this is a silly question, but is there a ruler function? I would like to be able to measure between certain points/lines/planes easily to know where to cut out shapes, etc. Thank you!
If you make a construction plane then use the line tool.start and end points on what you are trying to measure, then hylite the line it will give you a measurement to the side. There is a 2ed alternative at the bottom of the screen there are measurements as well.
I uploaded a simple free ruler from the App Store perfect for the job
Thank you, but it is still very tricky when trying to line something up accurately.
Oh interesting, which app?
It’s called free ruler on the App Store. Hope that helps👍
